Total Recall issue - can't calibrate <sorted>
Started by SuperBaz, January 27, 2019, 11:50:16 PM
SuperBaz
Hi there. Having successfully built a Total Recall, I have attempted another. In this case it's actually a rack mounted, dual mono or stereo linkable version for studio use, ie. 2 boards.
I'm getting high pitch squeal and very distorted sound when calibrating IC6. No clean delay.
Voltages are good at the regulator. I've measured all voltages on IC1 through 9 and there is only one notable difference (same on both boards) - IC2 pin 7 is -12.23 rather than -4.71. On IC5, pins 5,6 and 7 are a little low (-5.95). Other than that, all is as it should be.
Given that I have a working version, I have tested the NE570 and CD4047 in it and they are ok.
Any suggestions? Please note that though I've built lots of pedals, and some studio compressors, I have no knowledge of electronics. I can follow instructions though!
Thanks in advance.
Bevan
Check ye R10 & 11 values (and R9 while you're at it too).
SuperBaz
Blimey that was quick, and accurate too. As you've no doubt guessed, I have put 6K8 in those three positions. I shall replace and see what happens!
Back soon.
Thanks!
SuperBaz
Success!
Thanks Scruffie, much obliged.
I shall post a pic once the faceplate is lazered.
Bevan
