Unicorn Tears
Started by cooder, March 07, 2019, 06:12:50 AM
And don't we love some overdrive goodness...
Here's one built ob pedalpcb 'Pauper' pcb which is BuGG's take on Analogman 'Prince of Tone'.
Very nice sounds in there and great tweakability with internal DIP switchiness and pres trimmer.
I even had the 'magic' MA856 diodes to make the Unicorn more sparkly and weepy.
Acrylic face plate over laser decal, relay switching with 1776 finish line.
DLW
Wow! Very clean. Top mounted jacks in a 1590B is always an impressive feat. Did you have to notch the bottom plate to get it to fit around jacks?
Aleph Null
Nothing like magic diodes to make your overdrive more mythical! Are you using a plexiglass plate on the top of the enclosure?
How is the relay board mounted there?
Quote from: DLW on March 07, 2019, 01:08:11 PM
It's a 125B which makes it a bit easier and no notching or tricks required, just measure twice drill once and hope for the best.
Quote from: Aleph Null on March 07, 2019, 06:30:53 PM
Yep, acrylic faceplate on top. I did a little while ago a turorial on how I did that, I'll update that link in here in a sec.
Edit: Here we are:http://www.madbeanpedals.com/forum/index.php?topic=28358.0
Quote from: midwayfair on March 07, 2019, 09:37:55 PM
The LED is glued in with epoxy, the relay board soldered onto that which gives it already a bit of hold, kinda floating, and then a small amount of epoxy holding the board on inner side of enclosure. Never gave me problems doing it like that. The epoxy seems enough to hold it reliably in place and can be forced off if needed for repairs or alterations.
brejna
That looks awesome! Love your style.
