retrograde works, but has a hum active and bypsaa
Started by mikef, March 20, 2020, 11:14:45 PM
mikef
Hello,
Well, got the fuzz, got the octave..and some hum....any suggestions?!? bypass or active,btw.
mikef
First, I swear that looks like it says 2619 and second, is it like a ground him or 60 cycle him?
mikef
HUM............... (pun intended.)I will hook it up later this morning and take a listen........THANKS~ it is 2619 :o Might be on Beans double secret PCB list?
mikef
switched between bench power supply and 9v battery. 9volt was considerably less hum,whereas the bench power supply was off the chart loud.
Is your off board wiring hooked up properly, can't see it in the photos. Is the transformer oriented correctly?
mikef
here it is. Thank you for the help. I am flummoxed!
mikef
It looks to me like the  jacks are wired backwards.
mikef
lol! Man, I would not be surprised..........lemmy swap 'em and see!
mikef
