Rate LED orientation
Started by smallpoxchampion, June 15, 2020, 04:40:02 PM
smallpoxchampion
Finishing up this zero point mini build and just wondering which pad on the rate led indicator is the negative, I'm used to seeing the square pad as the positive lead on capacitors but the LED symbol has the flat side of the LED lining up with the round thru hole???
Got a meter? Check with continuity to ground. Or power it up and check it with a meter.
Schematic will show what component the pads connect to.
smallpoxchampion
