Paralyzer connections
Started by Blooze, December 18, 2022, 06:09:44 PM
Blooze
I posted this in the JMK section, but it doesn't get much traffic. I'm having trouble trying to connect two madbean boards with a JMK Paralyzer board to blend in the same enclosure. Bypass foot switches for each MB board FWIW. This is what I have so far, but I could sure use to help.
What is the issue, it looks good.
Where does the paralyzer get power from?  Looks like you have the LED from the Mudbunny, which could work if the CLR is jumped.  Not sure I don't have the schematics.  Also, looks like you have the black lead going to the square pad on the paralyzer.
Blooze
Quote from: jimilee on December 18, 2022, 06:45:23 PM
Just wasn't sure if it was correct.
Blooze
Quote from: Bio77 on December 18, 2022, 07:00:52 PM
Here's the Paralyzer connections. You're correct that the RLED would need jumpered and I have the +/- connections swapped on the Paralyzer.
Blooze
Fixed.  I had one of the returns on the Paralyzer incorrect as well. Hopefully this is correct.
