can i run the Aquaboy at 12vdc?
Started by joesatch, August 05, 2023, 11:52:22 PM
joesatch
AB 2016. My pedalboard only has one available ps tap and it's 12vdc. The pedal is all setup for 9v and working fine. ok?
Presuming you are using the MN3005 then sure. You may have to make a slight adjustment on the clock trimmer to get the same delay time but only by a hair, if needed.
