Dirtbag Won't Rock Now That It's Boxed
Started by tenwatt, February 09, 2012, 02:34:24 AM
tenwatt
Worked on my testing rig but now it won't.  I'm only getting the bypassed signal.
Not too bright....
tenwatt
Not too bright....
You need to ground both the input and output jacks. The plastic encased ones do not ground to the enclosure like the metal framed ones.
tenwatt
Quote from: madbean on February 09, 2012, 03:09:51 PM
Awesome!  I hope it's that simple.
Not too bright....
tenwatt
Perfect.  It works now.  My LED still won't light.  It's weird.  When I pull the AC adapter from the socket of the jack on the pedal the LED flashes once.  Kinda strange.
Also, now that the circuit has been boxed it seems to need to be biased again.  There's a LOT more distortion than there was before it was boxed.  Is that typical?
Not too bright....
Try engaging the switch an use your multimeter to read the cathode and anode pins of the LED. What do you get when it's supposed to be on?
