MY SLOWLORIS
Started by hnkyrocks, October 11, 2010, 03:08:38 AM
hnkyrocks
this is my slowloris...
[img=http://s1.postimage.org/aLzrr.jpg]
[img=http://s1.postimage.org/aLBWA.jpg]
i have a problem with my slowloris...switch pop when i use switch cliping diode...
anyone can help me?
sory for my bad english....thx
HNKYROCKS from Indonesia
hnkyrocks
Hnky....
You don't need to apologize for your english every post! We know it's not your first language, it's ok - we're getting you!
However, I don't know why your switch is popping. Can you give us some more details?
hnkyrocks
thx jacob....
when I tried  to change from led to the diode clipping from the switch.....audible sound like a...."duk"...
That isn't too surprising, actually. I think that popping comes from the difference is forward voltage from the different diode types. If you switched them back and forth a half-dozen times it might go away. If it really bothers you, put a 1n cap in parallel with the LED's (signal to ground). That might stop it.
hnkyrocks
thanks madbean...so its normally......???i will try put a 1n cap in parallel with the LED's.....
thanks for your help....
