Rangemaster + Tonebender power & LED wiring?
Started by stevewire, January 20, 2013, 08:29:25 PM
stevewire
Hello.  I'm lacking a little confidence about how to do two circuits, in one enclosure, with a single battery.  I have done a forum search and I am not sure that I get it.  I am using an external on/off switch and no external power.  I want to only use a battery for these two effects.  The PNP wiring is enough to make me rethink every time I am about to solder up the next wire.  In the past I built the Pasty Face and a couple of Rangemasters in their own enclosures.  They turned out great.
So far I only have the positive of the battery snap connected to the ring of the input jack.  The round side of the LEDs are connected to the A1 lugs of the 3PDT switches.  And I assume the flat side of the LEDs will connect to resistors and then the negative side of battery snap after the on/off toggle switch.  And I think I should also have two wires coming from the negative side of the battery snap going to each PCB?
stevewire
