Fab houses and internal cutouts
Started by jubal81, March 27, 2013, 03:19:42 AM
I just had to drill a mounting hole out to 1/2 inch because Seeed wouldn't do an internal cutout that big. Anyone have a tip on how to get a board fabbed with a 1/2 inch hole?
GrindCustoms
If you get any info about how to resolve that issue it would be greatly appreciated.
Usually when Seeed can't perform a particular job, i contact Sunny at iTead and most of the time we find a way to work it out.
I needed a particular cutout in a pcb, Seeed would'nt do it...but i got them made by iTead.
What i know is that they don't do «V-cuts» and need a minimum of 5mm between each cut or needed space to have the router properly working.
They should be able to do a route leaving a few tabs to the center that you can clip.  Another option would be to send a series of holes as a perforation, make sure to id as non plated.
GrindCustoms
Quote from: wgc on March 29, 2013, 11:16:14 PM
That's for panelized design, and they don't accept files like that.
Ok, but you do realize that you're buying small sections of a panel?  And they can do files like that, though they may not want to.  It boils down to how much programming they're willing to do.
I think there's a way to mark holes as plated or not in the library.  I've only just started doing layouts, and those are smt, but I spent about 12 years in electronic assembly and visited many pcb fab houses.
Quote from: wgc on March 30, 2013, 02:37:16 AM
There's no need to monkey with the library. Just use the "Hole" tool in the board editor. You can drop holes where you want, move them around, change the diameter, etc.
