can i put 2 resistors together
Started by evildead222, September 20, 2013, 06:30:21 PM
evildead222
can i attach 2 resistors together? For example, I need a 200 ohm resistor can i attach two 100 ohm resistors and if yes how do I do it?
irmcdermott
Yes. You can put two resistors in series. So in your case, you solder one leg of one to the leg of the other. Here is a picture: http://www.cooperbills.com/Projects/MXRevolution/pics/2resistors.jpg
Sometimes it's easiest to make a "teepee" to put them in the board.
evildead222
