Zero Point DD
Started by Tcheloviski, July 09, 2013, 09:34:49 PM
Tcheloviski
(1) Project Name: Zero Point DD
(2) General description of the problem: i get only Clean sound and Tick Tick Tick.
Power Regulator Very Hot.
(3) Steps that you have taken to try to resolve the issue:
Checked Wiring 10x or more
1 - Change the pt2399
2 - Change Transistors BC550B
3 - Change Power Regulator
4 - Change Position Of Transistors
5 - Change BC550B For BC108
6 - Change BC108 For BC550B
8 - Change TL072
9 - Check Diodes Position
(4) List any substitutions you used for parts/values
No Subs
You have a short connecting the 9v to ground somewhere.
Tcheloviski
the board have 3 grounds.
2 for 9v
1 for PCI Grounding
i connect 9V Ground in tip
the 9V+ in 9V
All Grounds in rig of input
Correct?
Tcheloviski
i'm holding for doesn't take a hammer and destroy the pcb
Coca cola time.
Ground = common -- all ground points in a circuit are connected together. It sounds like you have that correct.
The tick tick tick sound you've described would be caused by the +9v being connected to the ground. Use your multimeter, on the continuity setting, to see if the +9v is connected to the ground (it will beep). They should not be connected. If they are, then that is the problem you need to fix.
Sounds like a ground issue. How are you powering it? Have you taken any voltage readings yet?
Tcheloviski
Solved TODAY  ;D
Just change The IC and one capacitor.
Sounds nice.
Thanks!
