Sea urchin pcb mounted pots
Started by Gledison, October 22, 2013, 09:13:36 PM
Gledison
Hey guys,
in the thread of the sea urchin in extra projects, it says that is for a pcb mounted pots. i see only the feedback and mix aligne pots, the delay should be wired right? or im missing somthing ?
Thanks for any help
brejna
Gledison
Quote from: brejna on October 22, 2013, 09:37:46 PM
Just look above input :D
hey mate, yes the delay I see where it is, im just wondering that if one mount a pot there might end with a weird pot constellation...
or im still missing something :'(
brejna
Quote from: Gledison on October 22, 2013, 10:04:42 PM
Sorry I am stupid somethimes  :-[
Gledison
No worries! Look, did u build this pedal? From the layout it seems that inly 2 pota can be mountrd the delay should be wired... But what a f{%]^^¥$ do i know?😂
Please post a link in future, saves time.
It refers to right angle board mounted pots, the pots mount on the under side of the board, the pots would be in a triangle / \ that's why it's in from the right.
kothoma
#6
Use these http://www.musikding.de/Alpha-pot-angled-pc-mount-50k-lin or add solid core wires to pots with solder lugs.
Gledison
Quote from: Scruffie on October 22, 2013, 11:13:22 PM
You are right :http://www.madbeanpedals.com/forum/index.php?topic=2832.0
maybe a bit late :P, sorry
Actually the idea of the triangle i couldnt get it in the beginning. I thought that the pots will have different "starting point". Well, du to my lack in experience, i´ve just realized now that i can adjust the knob of the Delay pot to be in line with the other ones! with my previous 2 Builds i was following the instructions. I think is time to think more before start building :P
cheers mate!
Gledison
hi, i tried to allign the pots on a design and still didnt get a perfect fit...do you have a picture of you sea urchin guts? :)
i attached my pdf file as reference.
thanks for support!
chromesphere
Hey Gledison,
Sorry mate, I wired my pots in.
Paul
Gledison
Quote from: chromesphere on October 23, 2013, 10:37:50 AM
Hey Gledison,
Paul
Cheers Paul!
i might do that as well :P
