making a test rig question
Started by danwelsh, December 09, 2013, 07:48:11 PM
danwelsh
Hi guys. So I'm making a test rig but I don't have an extra 3 PDT stomp switch.....what I do have is a on/off/on toggle switch that has 6 pins. Could someone help me and tell me how the heck I would wire this up for my test box? Thanks in advance :)
rullywowr
No problem. You can use a Dpdt to do wiring but just without an LED. You could add an LED using the millenium bypass.
Just look at madbean standard wiring diagrams. You can use the 3pdt one just ignore the last collumn with the LED.
danwelsh
Quote from: rullywowr on December 09, 2013, 08:13:45 PM
Okay so looking at the standard wiring diagram I would ignore the first 3 pins and just use the ground with the dpdt on pin number 3? All the rest would be wired the same as the standard?
GermanCdn
In and out on the middle lugs, jumper the bottom set of lugs, board in and out on the top set and you're good.
danwelsh
Quote from: GermanCdn on December 09, 2013, 08:39:36 PM
Thanks a million
danwelsh
So what would I use for my ground?
danwelsh
Will a dpst switch work....just found out my dpdt is broken
GermanCdn
PM me your address and I'll send you a PIF 3PDT stomp.
rullywowr
danwelsh
#9
Quote from: GermanCdn on December 09, 2013, 10:22:17 PM
Thanks for the generous offer but I gotta order parts from tayda for my next build anyways so ill just order a few extras :)
UPDATE- I found 5 3 PDT switches I hid on myself and forgot I had. Lol
