100uf Capacitor in Big Muff
Started by playpunk, December 22, 2013, 02:07:03 AM
playpunk
Hey, did you know that this thing still works if you leave off this cap? I did, accidentally, and mine still worked. It wasn't very loud, but it worked.
Why? Is the electrolytic just a power-filtering cap, or does it have some other function?
"my legend grows" - playpunk
Guitarmageddon
If there's a 100uf cap in a Muff it'll be to filter the power supply. It shouldn't have any effect on the effect volume.
Spud knows tone!
Captain Cod at
www.codtone.com
Clayford
#2
Quote from: playpunk on December 22, 2013, 02:07:03 AM
Is the electrolytic just a power-filtering cap, or...
Correct. Worth mentioning that it didn't exist in the first few iterations of the BMP that were battery only.
If your Muff is not very loud, you need to double check things as there's a fault in your circuit.
chromesphere
^ what they said.  You may find there is extra noise in your big muff without the cap.  Which actually, most the big muffs I've built are quite noisey, even on a regulatored PSU.
