Mn3010
Started by PimpMyTone, December 22, 2013, 01:28:48 AM
PimpMyTone
Hi, I just found a small source of mn3010 and I was wondering if there is a project of a ADA flanger using that chip somewhere .
Simon
Quote from: PimpMyTone on December 22, 2013, 01:28:48 AM
http://moosapotamus.net/ has one. Don't know much about it but I had a build doc for one from there.
edit: its for the MN3007 I just noticed. Might work for you.
PimpMyTone
Thanks for the link . I never saw that website before .
Simon
I'm pretty sure certain revisions of the poly chorus use mn3010s
You could work something up around that
https://www.gigaheartsfx.com
instagram @gigahearts_fx
#4
Quote from: LaceSensor on December 22, 2013, 12:02:05 PM
It did not, it used SAD1024s and later a 3008 and 3009 which is probably what you're thinking of.
The A/DA is the only commercial design I can think of that used the chip, it wasn't used much, couple of rack mounts.
owned by scruffie
its not a bad thing
