Reeeveeerb?
Started by pryde, December 20, 2013, 10:34:40 PM
chromesphere
Yeah I agree with juansolo.  I reckon your friends request is out of the diy field.  He should just buy a Big Sky or something. Expensive, but as you said Pryde, he's being picky.
pryde
#16
Thinking I might try to re-house a biyang rv-10 into the effect as he seams to like the reverb it produces.
Will need to run new pots off-board to the face of the rack unit, then figure out 9v, ground, in/out on the pcb to run to a new 3pdt toggle on the face as well. I think he will settle on 1 internal setting (toggle switches on the board).
Not going to worry about the stereo in/out options, just going to use the mono path. Any issues/problems with this approach?
chromesphere
Not sure Pryde, but I was wondering, what chip does this effect use for its reverb effect?
Should be pretty straight forward. I rehoused a Danelectro pedals last year and it was just a matter of removing their pots and placing mine and I converted it to true bypass. Nothing to crazy.
pryde
Chip is 3201 processor in the unit. I have only heard demos but it sounds pretty decent for $50 I think
Sent from my SPH-L710 using Tapatalk
chromesphere
had a quick look at the datasheet, unfortunately way above my head.  Looks like some digital programming involved.  (AL3201BG)
claytushaywood
the old bricks dont have modulation?  wow!  I wish theyd make the new ones without modulation in all the different decay times.
I can attest to the fact that the short decay time has less modulation than the long- quite a bit less.
And id also like to note that the decay times have nothing to do with slapback echo in my experience.  you can get it to slapback with any decay time.  just depends on the circuit implementation
Yeah bear in mind the delay times aren't massively apart (200/250/280ms IIRC).
Quote from: pryde on December 23, 2013, 01:35:01 AM
That's the same chip as in the Dr. Scientist Reverberator. You could build something relatively similar with the Femtoverb project, which uses the AL2013 also.
Brian and I also worked on a basic FV-1 project (some time ago), which I presume is what he plans to release in the near future. As we left the project, you have access to all of the on-board programs that come default in the FV-1, a few of which are reverbs (and they sound pretty damn good).
claytushaywood
Quote from: juansolo on December 23, 2013, 09:50:42 AM
its actually
2 seconds
2.5 seconds
and 2.8 seconds
not ms
and those are decay times, not delay times
destro
If the old style large bricks don't have the modulation than Earthquake Devices Ghost Echo would certainly be different between their big box and small box models. Hmmm....
Quote from: destro on December 27, 2013, 12:21:11 AM
My *recollection* is that the big/old bricks do not have modulation (or not nearly as much). I built a few of those and never noticed modulation, whereas I immediately heard it when I fired up the first small brick build.
Quote from: claytushaywood on December 26, 2013, 11:02:14 PM
its actually
2 seconds
2.5 seconds
and 2.8 seconds
not ms
Indeed! I sit corrected.
