V3205 at Mammoth
Started by diablochris6, January 22, 2014, 05:34:04 PM
diablochris6
Mammoth Electronics has V3205 ICs for sale, but the picture is a computer model that resembles a smaller 8-pin IC like a TL072.  The datasheet for the V3205SD doesn't match the picture on their site.  I have e-mailed them to ask for clarification but have not heard anything back from them.  If there is anybody that has bought them from Mammoth, can you tell me if they are indeed small like an op-amp or if it is the longer ICs more common in the builds around here?  I am trying to design a pcb and will most likely order the ICs from them, so I need to know their size.
They are the larger size. It's a 16-pin sized package, but with 8 pins spaced out. Like a MN3205 or MN3005.
Quote from: culturejam on January 22, 2014, 06:11:39 PM
14-Pin sized, just to clarify.
Whoops! Thanks for the correction, Scruff.  8)
diablochris6
Thanks for the clarification!
