How to convert 2kB pot to 1kB
Started by Jabulani Jonny, May 31, 2014, 10:48:22 PM
Jabulani Jonny
Hey guys,
looks like the only thing I'm missing from finishing up a Cosmo build is a 1kB pot.  Can I strap a resistor across the pins of a 2kB to get what I need?  If so, and looking specifically at the Cosmo, how would I go about doing that?  Many thanks!
Jonathan
Put a 2k resistor across lugs 1 &3.  The taper will change a little, but it will work.
I suggest using a C1K if you have one.  I think it works better there.
Jabulani Jonny
Awesome. Thanks Pick. I should've been able to figure that one out. Unfortunately no C taper pots close to that value.
Jonathan
