Harbinger One / Univi --> need more volume.
Started by guile, May 21, 2015, 06:21:36 PM
guile
Built the Harbinger One, sounds great but is it possible to increase the volume? It barely reaches unity gain.
Thanks!
luks999
at modern mode the harbinger should have plenty of headroom
i would recommend check your resistor values...
yes theres also a mod to increase unity gain
take a look at RG keens neovibe:
http://www.geofex.com/Article_Folders/univibe/vibeupdate.pdf
page 4 - but it increases gain as well, so the unit will distort a little bit
guile
Quote from: luks999 on May 22, 2015, 10:09:11 AM
Thanks.
So 'change resistor R9 to 3.6K and resistor R8 to 910 ohms' Got it will report back
luks999
exactly, even though i didnt like the mod, because i want my univibe to add zero gain
but the volume is definately increased
but it seemed like the only way for the neovibe
in the harbinger theres the modern input, which should have enough headroom
the mod will only apply for the vintage mode
are speaking of the modern or vintage mode? or have both a volume drop?
guile
The vintage mode is way too low and the modern mode is barely unity gain...
