Retrograde reverse polarity
Started by teknoman2, September 10, 2014, 09:48:08 AM
teknoman2
I just order an retrograde and I was thinking using PNP instead NPN transistors just like the original.
I will reverse all the caps and feed the board with -9v probably wont face any issues.
Should I make any other changes?
Also regarding the audio transofrmer If I use different ratio turns will be noticeable audio difference?
Cheers,
Panos.
teknoman2
