Tube Driver - Sound clip added!
Started by Thomas_H, August 29, 2014, 08:01:51 AM
Thomas_H
Hi,
finally I managed to cram this Tube Driver into a 1590B enclosure.
Although it worked with a lot of time spent I can not recommend this. Use a 125B and you will have easy going ;)
I am still tweaking this a little at the moment but build to the known specs it sounds like the real thing.
There is some more background info here: http://www.madbeanpedals.com/forum/index.php?topic=17209.msg163886
Here are some pictures:
DIY-PCBs and projects:
Gledison
looks fantastic! Sti want to build one myself,
Lets see!
What about the blue letters, seems like vinyl, what are they? Amazing!
muddyfox
I got a similar effect by using P'n'P Blue once...
Thomas_H
This is an inverse laser etch.
Quote from: Thomas_H on August 29, 2014, 12:12:15 PM
Bet that took a while.  :-)
Looks great, though.  Very nice build.
The fabrics of time were just ripped. Really awesome.
Thomas_H
https://www.gigaheartsfx.com
instagram @gigahearts_fx
brejna
Great work, I am glad that you've verified this one :D
GrindCustoms
Very nice! Now i want one just to fit it in a 1590B :)
Glad you bumped up the voltage to plates, if it had the parts rated for it, i'd be curious to hear it with a 18V supply source.
All the tubey i did using the 6.66 Multiplier where running from 18 and had à significant difference compared to 9V.
Thomas_H
As requested: Audio demo of the new tube driver pedal.
Partscaster -> Tube Driver -> Clean Tube Amp Channel. No added effects.
[soundcloud]https://soundcloud.com/th-custom-effects/tube-driver-audio-demo[/soundcloud]
