So, I burned up a diode on a Pasty Face.....
Started by strat68, September 23, 2014, 04:09:28 PM
strat68
and what else may have gotten damaged?  I forgot to reverse it when I did the Si version of the pedal.  I get good sound up to the base of Q3 and then some quiet buzzing on the collector.  I think I have the transistors oriented properly as the pedal seems to work fine up to that point.
The plan is to do some detailed debugging and then post the details when if I can't get it to work.  But I wanted to see if there was an obvious answer to a fried diode.  Matches my board designation.
Thanks
