Slow Loris Accident!!
Started by latestsaint, September 28, 2014, 10:59:54 PM
latestsaint
Hey guys.  Well i had my slow loris tested and working (the thing sounds killer btw!) so i drilled out my 1590b enclosure and started stuffing.  i ran into a problem (as i always do) with the Cut and Gain wire lengths so i had to resolder longer ones in.
When i went to wire up the power i may have wired it reversed polarity.  Now ive got it back on the test rig and i am getting no output.  Did i accidentally fry something?  i know the power stage of this circuit is a little complicated but what would be the first thing to check if i did accidentally power this thing backwards?
also, i changed out the socketed chip and transistor with new ones to see if that was the problem.  still no signal
thanks in advance!!
j
I'm guessing you just have a short from something touching the box, broken solder joint, wire, etc.  take it back out and see if it works then.
Almost always simpler than you think, but not always easy to see.
Blues Healer
if it works out of the box, then not after it's boxed, one of the first things I'd check is your ground connections, especialy on the jacks
"music heals"
Loose
If you plugged in reverse polarity without a polarity protection diode then you'll have to replace the diodes and chip and transistor
latestsaint
Quote from: wgc on September 28, 2014, 11:39:12 PM
thats exactly what i ended up doing.  found out it was these crappy metal dc jacks i was using.  i noticed when i was taking out the jacks and the dc was still plugged in.. i got a little spark on the enclosure.  anyways ive go it all wired up and jammed in a 1590b.  it sounds awesome, and i love how you can see the leds light up when you use their clipping stage (i drilled two extra holes for these btw  ;))
now the only problem im having is the clipping stage cutting out sometimes when the leds get jostled or moved.  probably some loose connection or it may be grounding out...  i guess ill find out when i gut it again to paint the damn thing.  but it sounds awesome!  not bad for my first rat prototype.  definitely going to give this one another shot in a bigger enclosure so i can fit a battery  8)
later guys thanks again
Good work!  Double check all your solder joints when you have it out.  Maybe touch some of them up.
Enjoy!  I love a good rat!
Josh
Awesome, glad it was something simple. The LEDs might just need a reflow when you get everything mounted. Check the switch too. It can be easy to fracture a joint when trying to manipulate everything into place. Love my rat!
latestsaint
i reflowed(sp?) the solder on the LEDs and that seems to have done the trick.  no more flickering in and out of the clipping stage  :o
other than that, this things is solid as a rock, and is probably the gnarliest distortion on my board right now.  it sounds good with a bass too if you dial back the pedal with the sweep mod.
now its time for paint!!!!   :)
later on fellas
