Aquaboy DX - No more Delay
Started by dan.schumaker, February 04, 2015, 01:23:46 AM
dan.schumaker
So I built up the Aquaboy DX (V3205) last night and got it all setup and dialed in.  Good sounding delays.  I boxed it, tested again, still good sounding delays.  I went to play through it today, and no more delay.  I still get bypass sounds and when the pedal is on, still clean sounds.  I am using V3205's for the BBD, V3102 for the clock and NE570 for the compander, all powered by a 9V One-Spot.
I went through the troubleshooting on the build doc, and got clean audio through pin 7 of the compander, and clean audio through pin 7 of IC3.  I double checked my jumpers and they are set correctly, with pin 1 of the BBD's at 0V, and pin 5 getting 8.17V.
Funny thing about this is that I built up a Dirtbag Delay with V3205 chips and had the same issue happen.  Works great for a day or two, next day its done (I haven't resolved that one either).
Do you think it could be a case of bad V3205's?  Its just very curious since the same thing happened to a Dirtbag.  Maybe its something I am totally overlooking, a part that I added that I shouldn't for this kinda powering.
My voltages are:
IC1
1  4.50       8  8.99
2  4.50       7  4.49
3  4.49       6  4.50
4  0.0         5  4.50
IC2
1  1.15       16  0.92
2  1.76       15  1.76
3  1.76       14  1.76
4  0            13  8.99
5  1.76       12  1.76
6  1.76       11  4.50
7  3.03       10  4.50
8  1.76        9   1.76
IC3
1  0.0       8  7.69
2  4.07     7  4.46
3  3.62     6  4.07
4  3.65     5  8.17
IC4
1  0.0       8  7.69
2  4.07     7  4.90
3  3.56     6  4.07
4  3.59     5  8.17
IC5
1  8.18       8  7.70
2  4.07       7  3.93
3  0.0         6  4.30
4  4.07       5  3.84
IC6
1  3.23-5.56     8  8.99  (couldn't read my chicken scratch here)
2  4.39-4.61     7
3  4.39-4.61     6  4.39-4.61
4  0.0               5  4.39-4.61
Here is a picture of it boxed up (when it was working last night)
Thanks for any help in advance
Voltages look okay, i'd audio probe.
frespe
I can't tell from the picture whether if you put a D1 or not
