Eagle
Started by darrenw6000, April 24, 2017, 09:36:33 AM
darrenw6000
I have my board outline done but not in the correct width, now without having to re-do the board outline again can i somehow increase the board width. help is appreciated. Thanks
The lines of the board outline can be edited and moved. I'm not sure if you have tried yet, but you can use the move tool, or you can right click on the board outline, go to properties, and manually edit the x and y points for both ends of each line.
Jaco
if by width you mean line width you can adjust that by going to the change tool and select the appropriate width. Now you can just click on all the lines you want to adjust.
darrenw6000
yes, i've found the 'i' icon, selected a line and changed the width there in the properties type box...its been a while since i've used this program, thanks guys
darrenw6000
another thing, MBP library file- for a DPDT stomp is it the one labelled 'DPDT PINS?
DPDT.PINS will only work for one with pcb mount pins, not with solder lug type stomps, at least I think so. If you need one for the solder lug type stomp I can send you a library that contains one. if so, PM me your email address.
