1/8 Resistors
Started by Timko, May 24, 2017, 03:07:37 PM
Timko
This summer I seem to have collected some 1/8 resistor projects to work through (a couple of Kyrpton phasers, a Pangea Tremolo, and the very daunting Nameless Flanger).  I have been ordering the cheapie 1/4 resistors from Tayda for a while, but I've been making the switch to ordering components from Mouser for my last 2 orders.  I've looked at past Mouser orders I've placed, and the Xicon resistors I've ordered have been 6.8 mm in length.  I can tell from the boards that the 1/8 watt are smaller.  I think from my searching that I'm looking for something half off that size (3.5 mm).  Am I on the right track?
http://www.mouser.com/ProductDetail/Xicon/270-47-RC/?qs=sGAEpiMZZMu61qfTUdNhG%2fx58qVkkJBru51SUIEDxOY%3d
Also, is there some cheaper place to get these?  I suppose I'm spoiled ordering 100 metal film resistors from Tayda for a little over a dollar, but man.
micromegas
I used to buy all my 1/8 resistor from Paul: http://www.diyguitarpedals.com.au/shop/index.php?main_page=index&cPath=19_21
0.06 AUD for each resistor seems a good deal to me, and Paul is a really nice guy to deal with
Software Developer @ bela.io
krisk
I've had good luck with getting 1/8w sized ones from Arrow. They have a lot of the common values in the 3.3 mm in 1/4w from Stackpole. Right now they have free shipping with a $20 minimum.
Betty Wont
Tayda does have 1/8watt metal film resistors at a penny each. I use them for the same projects you listed and they are fine.
Timko
Quote from: Torgoslayer on May 24, 2017, 03:39:36 PM
Honestly, I didn't even look at Tayda because I assumed they didn't sell them based on some older post on the forums.  Thanks for the info! I already have a potentiometer order to place with them, so I'll order these as well.
If you're searching for resistors at Mouser/Digikey, instead of filtering the search by wattage, filter by physical size, you'll end up up with hits for 1/8, 1/6, 1/4 maybe even 1/2w, been awhile that will fit the footprint.
Timko
The physical size is somewhere around 3.5mm right?
bsoncini
I built two of those projects you mentioned. Krypton and pangea. I mostly used tayda 1/8 resistors and the rest stand up 1/4.  Worked perfectly.
Betty Wont
Quote from: Timko on May 24, 2017, 04:30:38 PM
Yep
Dimensions for 1/2, 1/4, and 1/8-watt are on page 1.
I get 1/8W resistors from tayda, these days.
