Krankosaurus LED wiring diagram
Started by Jordo, November 29, 2010, 07:16:07 AM
Jordo
I am desperate for a wiring diagram for krankosaurus that includes wiring for leds.  I have searched for diagrams but I have found inconsistency in a lot of them.
This is the best one ive found but i am confused when it comes to the grounding...
http://www.generalguitargadgets.com/pdf/two_in_one_wiring.pdf?phpMyAdmin=78482479fd7e7fc3768044a841b3e85a
Please help.
stecykmi
that's a perfectly valid switching solution. when the switch is on, the cathode (negative side) of the led is connected to ground, thus completing the circuit. when the switch is off, the cathode is floating so the circuit is incomplete.
if you're not sure about switches, read Beavis' tutorial on them, he lays it out very nicely: http://www.beavisaudio.com/techpages/Switches/
on another note, the user "pandadandan" posted a really great switching solution in this thread:
i use this one all the time now because you don't need a pulldown resistor, i recommend it.
Jordo
Thank you very much for your reply stecykmi!
I will read suggested info and let you know how i go,
Just in case it got confusing because the two links appear to be the same, not different...
http://www.madbeanpedals.com/forum/index.php?topic=602.msg3801#msg3801
stecykmi
oops, i need to proofread my posts, or stop posting in the middle of the night.
here is the actual post by pandadandan that i was speaking of:
http://www.madbeanpedals.com/forum/index.php?topic=15.0
Jordo
Brian draw this up and I am grateful.  He is a CHAMPION!
http://s908.photobucket.com/albums/ac286/Jordnowe/?action=view&current=krankLED.gif
I feel like a complete noob and im tired of relying on others so i am gonna knowledge up!
Thanks
Jordo
Thanks stecykmi btw I have read the beavis audio stuff and understand alot more about switches.
Cheers
I will be posting pics of build soon!
Guybrush
Sorry to drag this up but I have a small question and didn't think it worth starting a new thread. The LED wiring that Jordo posted is really helpful but it only shows wiring for attaching an LED to one of the switches.  I would like to have an independent LED for each switch and was wondering if this would work?
Thanks in advance.
Hey mpsya
That would work except that you should have both LEDs from the same 9V lug on the DC socket. If you wired it like that you'd only get the 2nd LED when using a battery, not with power supply.  :)
So like this instead:
Guybrush
Balls, that's what I meant to draw. It's been a long day! Thank you for putting me straight! Greatly appreciated.
