Parts lists for Wolfshirt
Started by clangmeister, December 05, 2011, 12:49:08 AM
clangmeister
 Hi folks...
I etched a Wolfshirt and a Sunking. Wondering if the component numbers that are listed under the fabbed version of the Wolfshirt match up to the etched version... since there is only one list.
  I discovered after mostly populating the Sunking that there were 2 seperate numberings :'( and (alas) I used the one under the Fabbed version...
thanx!
bigmufffuzzwizz
Just followed the first few connections up to about R6 and my guess is they are the same component numbering.
clangmeister
Thank you Dr.!
Yeah... I guess the way is to check the schematic against the tracing..
cheers
bigmufffuzzwizz
Quote from: clangmeister on December 05, 2011, 10:22:31 PM
Thank you Dr.!
cheers
Yes its kinda tedious at first but gets easier with more practice. I actually was comparing the two layouts to each other  :)
