Add LED to mudbunny tone dpdt?
Started by thesameage, June 15, 2021, 08:09:22 PM
Zerro
#15
Look upstairs reply #5
thesameage
thesameage
#19
This worked! You can see that the board has space for a PCB mounted dpdt switch. I just ran wires to a dpdt footswitch so that I can have easier access.
thesameage
I think I just need to put in a 3dpt switch and add a ground and LED connection. I was playing the pedal this weekend and it seems pretty important to know visually when the tone bypass is on.
Are any of the pins grounded when it's bypassed and not when it isn't?
Don't think any of the pins are grounded. Swapping to a 3dpt is probably the best way to get it done.
thesameage
As far as I can tell, none of the pins are grounded. That would solve the issue right there.
