Adjust LP and HP filters
Started by LaceSensor, September 24, 2025, 06:42:11 AM
Had a request to adjust the sweep range of this project .
https://docs.pedalpcb.com/project/FrequencyInterchange-PedalPCB.pdf
Does anyone have a good calculator for the type of LPF and HPF here? Im comfortable with one-potentiometer LP circuits, but these are dual-gang and I am not sure how to adjust the capacitors/resistors to effect the change.
The desired range is LP - 1k to 6k HP 30-250hz
Thanks for your help
Ian
https://www.gigaheartsfx.com
instagram @gigahearts_fx
Ive been reading some documents on second order filters and I cant even get the example maths they provide to work with their "default" circuits.
eg https://k7mem.com/Fil_2nd_Active_LP_HP.html
eg https://www.electronics-tutorials.ws/filter/filter_6.html
Any help would be super appreciated!
Cheers
mauman
You could try a sim in Spice and experimentally tweak the components around the LP and HP pots, there aren't that many.
NorthCoast
"People discuss my art and pretend to understand as if it were necessary to understand..." - Claude Monet
