Mudbunny help
Started by rlopes, January 16, 2012, 12:06:18 PM
rlopes
Hello!
I'm about to finish my first madbean project: the mudbunny.
I used a 1590B style enclosure and made a mistake when i drill my enclosure and i install the 3PDT a few mm down so now i don't have space to fit the 9v battery in the enclosure. That's not a real problem because i use a power supply to power my pedals (the 9v battery was just a backup option). But now i don't know if i have to make some changes in the mudbunny wiring in order to use only the DC adaptor option. Can i simply omit the 9v battery snap wiring and do the rest of the wiring as presented in the mudbunny wiring diagram?
Best regards to all of you
Loztboy
Yes you can.
You can then use a monojack on input if you want.
rlopes
Thank you.
I have a stereo input jack instaled in the enclosure wich i already have started wiring and the only thing that wasn't finished was the power section because i want to be sure i wasn´t going to damage anything by omiting the 9v battery snap. This time i will use the stereo input so this means that i will leave the ring with no conections am i right?
Loztboy
rlopes
Thank you once again. I will post some pics in the finished projecs soon.
