Boneyard Whistle
Started by andregarcia57, February 26, 2012, 02:44:03 AM
andregarcia57
hello how are you?
I'm with little problem in Boneyard.
I used shielded cables and yet when volume greater than 6 is a "whistle" on the pedal
What could it be?
thanks
André
oldhousescott
Which version of the parts values did you use, the "stock" or the "modified" values? Also, which DC-DC converter (IC2) did you use?
andregarcia57
Quote from: oldhousescott on February 26, 2012, 08:54:59 PM
I used stock, MAX1044 IC, the problem happens only when volume above 6, is not feedback, but whistle.
