Grapevine rock/rawk switch wiring
Started by atreidesheir, June 13, 2012, 07:02:33 PM
atreidesheir
I am finally building my grapevine I purchased 18 mos ago.
I want to wire the rock/rawk switch 3pdt switch and I am not skilled enough to lay it out.
I have read posts from other members about this, but I have searched and cannot find a wiring diagram for the footswitch.
Can anyone please show me how to wire the switch?
thanks.  I hate to ask for stuff, but I am trying to do this the correct way.
atreidesheir
If I exclude C6, C7, and C8, and R7 and R8, would I need a jumper on the switching pads to just exclude the switch altogether and have just the Rock mode.  I do not care much for toggle switches.
atreidesheir
Should I post this in the tech help forum?
I'm confused with what you're asking for. Perhaps you simply need to clarify. The wiring diagram for the switch is in the build documents. As for removing a mode, I'd have to double check the schematic.
atreidesheir
Thanks,
I mean to remove the Rawk mode.
What I recommend you do is to fill in all the parts, then pick the mode you want to play through and use jumpers to make it permanent.
