Honeydripper cap question
Started by octa805, December 27, 2012, 03:04:38 AM
octa805
I used some BOM for mouser I found on the forum and it came with ceramic caps instead of electrolytic. They are the right value. Can I use them with no ill effects? Thanks
Haberdasher
which cap numbers are they on the BOM?  are you sure they aren't tantalums?
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
octa805
got it from over here:
http://www.madbeanpedals.com/forum/index.php?topic=5703.0
the caps are these guys:
   Multilayer Ceramic Capacitors MLCC - Leaded 2.2uF 25volts X5R +/-10%
they are in C9-C11 and C18 &C19 I believe
thanks!
Haberdasher
c9-c11 should be cool
I think 18 & 19 should be polarized 10uF's
octa805
hmm. ok. for my own understanding more than anything, why would there be a need in that location for polarized caps but not in C9-11?
I might give it a try anyways cause I'm impatient :)
thanks!
Haberdasher
#5
well I don't think you should use 2u2 there; that's the main point I was trying to make.  honestly i don't know if they need to be polarized but 10u caps usually are polar.  Those 2 caps are in the power section, while 9-11 are caps down in the audio portion of the circuit.  if you look at the schematic you'll probably see what i mean.
if you're in the states and need a couple of 10uF electro caps I might be able to help you out.
octa805
thanks. appreciate it!
just went through my meager stash of spares and actually found a pair of 10ufs so I'm set. it was like finding gold. :)
almost done now. hopefully this sucker will fire up later. thanks again.
