The Bigger Muff
Started by pickdropper, April 13, 2013, 02:34:10 PM
Then they expand, right?
Yep, they expand as the bubbles escape until the bubbles do escape then they collapse into a sad, deflated peep.
rullywowr
Nice pedal!  Is that a 3mm or 5mm frensel lens?  Do you use a yellow led or clear?  Just curious.
Quote from: rullywowr on April 15, 2013, 07:26:18 PM
That is a 5mm yellow lens with a yellow LED in it.
Thanks for the kind words.
rullywowr
Thanks for the info.  So if you use the lens and the spacer, you don't need to have one of those black plastic panel mounts?  It is a bit confusing looking at the data sheet from mouser.
Yeah, the lens and the spacer are all I use.  That is usually enough to hold it in place, although you could glue it to make it extra secure.
rullywowr
Thanks again!  Can't wait to start dresssing up my builds with these lenses.  ;D
