What should I socket on a Tonebender?
Started by lincolnic, May 06, 2013, 03:39:15 AM
And before anyone says it, yes, the transistors are first.
So I'm gearing up to build a Mk I or Mk II (probably going to do a Mk II, just for ease), and I know there's a lot of room for experimentation in these circuits. For those of you with more experience, which components have you found the most beneficial to play around with? I'd guess at least the input and output caps, but I'm open to suggestions as far as anything else I should try.
stecykmi
take a look at the pastyface build doc and take note of the components that vary from version to version, especially the caps. socketing the diode might also prove useful.
note that the tone control caps also serve as the output caps.
