IC 741 from smallbear & dist + from effdub?
Started by octa805, May 26, 2013, 07:02:56 PM
octa805
Is that IC compatible with that circuit with no mods?
pretty sure. The Dist+ uses a single op amp if I'm not mistaken, so that's a good choice. Any single op amp will work in place.
octa805
Do you have to use the built in CLR to make it work?
The built in CLR will only apply to the LED. It's not essential to the circuit, just to the LED.
octa805
Quote from: octa805 on May 26, 2013, 10:18:59 PM
Hmmm
Well then why is it not working? :)
Have you seen the rules for getting tech help thread? Go check that out, and see what you can learn.
There are many, many reasons it might not be working yet.
octa805
It was a joke really but thanks!
I just had the CLR in there but wasn't using it. Just clipped it and it works
Appreciate it!
