Andromeda 2.0
Started by pickdropper, June 08, 2013, 03:56:05 PM
Quote from: GrindCustoms on June 10, 2013, 05:34:12 PM
You Sir know how to impress me! ;)
What are those bezels fixtures?
Nothing terribly exciting.  Each one is a stack of two black acrylic circles.  The top circle is sized to fit the LED.  The bottom circle has a larger 1/4" ID to match up with the hole and the box and the acrylic front.  If I used the same ID for both, it is possible that the ringlight would be partially obscured (although I didn't test it).
GrindCustoms
May not be exciting, but it's clever.
P.S.: If you're online later tonight....hit me if you have time...;)
Roctopus
this is amazing! such craftsmanship. very impressive
aballen
Alright man,  when are the andromeda boards coming out ;)
Really cool idea to make the screwdriver/BMP run off dual gangs.
I was blown away by the last andromeda.  I don't have words for this one.
What size enclosure are you putting that all in?  It must be the size I a briefcase?
It's a 1550G.  Definitely not a smaller sized case.
And thanks for all of the compliments.  I always appreciate getting feedback from the folks here.
aballen
Thats not so bad, my power supply is in one of those.
I was just comparing the two, and surprisingly the 2.0 looks even more polished.  I think the additional plate across the bottom gives it a crisper more consistent look....
If you don't win the June content with this I'd be amazed.
Quote from: pickdropper on June 11, 2013, 02:48:22 AM
