VU meters for pedals?
Started by GhostofJohnToad, June 14, 2013, 05:19:54 PM
angrykoko
ValveWizards GlassBlower "GTI" has a LM3916 based led VU meter that you might try.
http://www.valvewizard.co.uk/glassblower.html (Bottom of page)
QuoteThe VU meter is done in the usual way by sending the audio to a peak level detector and then to an LM3916 audio-taper LED driver. Although this chip is designed to drive 10 LEDs, it is not easy to get the full scale out of it with only 9V available, so I used six LEDs.
It's the last one in his build pdf and the full schematic is there toohttp://www.valvewizard.co.uk/glassblower.pdf
Koko
The early bird may get the worm, but the second mouse gets the cheese in the trap.
aballen
That guy always has amazing stuff.  As soon as I have time I'm building an engineers thumb.
spaceboss
Quote from: jimilee on June 15, 2013, 04:22:32 AM
Quote from: spaceboss on June 15, 2013, 04:00:13 AM
I'm also very interested in this curious how you'd hook something like this up to a pedal, to show output
(I'm not even remotely interested in it being properly calibrated, I just want to see the meter move when I play. )
Hell yeah! Guitar players are the coolest. My guitar player took his tuner off his board so he could have room for another dirt pedal!
/derail
Not that the tuner is important, it isn't.  ;D But if your guitar player still doesn't have enough room, he can always Velcro new dirt pedals on top of existing dirt pedals.  8)
Quote from: spaceboss on June 15, 2013, 03:39:59 PM
/derail
right he just tunes to me after I tune, I suggested a bigger pedal board.
RobA
billstein
/derail
If you get enough dirt pedals turned on nobody will know you're out of tune anyway.
pedalman
pedalman
