Fuzzface volume pot reducing
Started by garfo, July 27, 2013, 11:02:14 AM
garfo
Old thread coming back to life.I'm messing up with my fuzzface and replaced the 500k pot with a 250k.Eventhough it became a tad less mushy and bassy it also increased floor noise and hum.
Has anyone had the same experience???
That shouldn't have happened ... It's just a master volume, and smaller resistors also produce less thermal noise.
Check the positions of your wires and make sure that your ground connections are still correct.
ChrisM
Quote from: midwayfair on July 27, 2013, 02:07:10 PM
That output cap and pot form a high pass filter so the less bass is to be expected.
Or maybe you were commented more on the noise.
garfo
I found the problem, my pedal was built fulltone 69 style and I removed the countor pot.WhileI did that didn't replace the resistor.Now I've put a larger resistor in there and the volume is back.It's sounding good, these 1t308B and mp39b transistors nail it for sure.
garfo
Quote from: garfo on July 27, 2013, 08:07:38 PM
It's sounding good, but it still has huming!!!
garfo
My ground connections are correct, plus I'm powering it with a batery, it still hums a bit.I'm surprised that it hums in my small transistor combo, I would expect that from my valve amp, but not on this one.
garfo
I found this when googling about hum cancelling a fuzzface;is it correcto?:
"To reduce hum, insulate the output jack from the case, leave the input jack attached to ground, and make sure no other parts of the circuit are tied to chassis."
