Enclosure smaller than Hammond 1590 LB?
Started by Beedoola, August 03, 2013, 05:38:33 PM
RobA
Beedoola
Quote from: RobA on August 03, 2013, 06:18:06 PM
The LLB is a tiny bit smaller and shorter.
http://www.hammondmfg.com/dwg.htm
Thanks for that. Yes it is smaller but not by much, lol. I may just stick with the LB.
icecycle66
If it has to be metal, I don't think so.
You can get some really tiny plastic boxes.
RobA
Quote from: Beedoola on August 03, 2013, 07:23:57 PM
I don't know, it's 1 whole millimeter per side smaller :D.
Actually, I don't think that Hammond boxes are even accurate to 1mm in dimension.
Beedoola
Quote from: icecycle66 on August 03, 2013, 10:14:43 PM
thanks, I should have clarified. No, it doesn't need to be metal, it would be for a Tap Tempo box so just needs to hold a momentary switch and jack.
icecycle66
Are you familiar with digikey.com?
Go there.
Search for "boxes"
then a big list of related things will come up.
click on "Boxes" out of the list; it should be fourth from the top of the links.
Once it brings you to the product list, you can select all sorts of size and requirement parameters.
Or you can click this link.
http://www.digikey.com/product-search/en/boxes-enclosures-racks/boxes/2163622?k=boxes
