ZPSDX - AlanP
Started by alanp, August 08, 2013, 03:14:59 AM
Zero Point Superdeluxe, another Madbean creation.
Photography is a bit crap, but I seriously have to get to bed. Plus you've all seen Zero Point guts before. Consider it hiding my poor wire-fu, if you like.
Soldered the breakout board on the wrong side, so wound up just doing John's switch work. It is not the easy option, btw, annoying to wire up. Analogue and Tape are the only options on Mode, hopefully won't miss Shimmer and Deep too much.
Definitely going to try this in the Flange's FX loop instead of the Dirtbag.
soldersqueeze
A painted enclosure?  :o
You sold out man.
I don't miss 'em. The active filtering slays the passive. It is fun to wire the first time though ;) I wired my second one on the top so I could use the photo for reference in case I ever do another :)
I dig the shimmer mode. But tape is the main one for sure.
