the two-headëd BLÜE MONSTER rise again, as ver 1.1 :)
Started by Vallhagen, August 10, 2013, 10:59:19 PM
Vallhagen
BLÜE MONSTER
Dual Band FET OD, ver 1.1
Late 2012 i designed and build the Blüe Monster highgain thing. The story, schematic, a onesided pcb-etch design, and sound clips are here: http://www.madbeanpedals.com/forum/index.php?topic=6968.0
... and evolution shrinks stuff, even here at my workbench. And as i kept developing my EAGLE skills (all thanx to this fantastic Place, that must be said again and again!) and also realized that i can order fabbed PCB-s for a ... reasonable amount of money, i decided to design a twosided PCB for the Blüe Monster myself. Definately exciting to populate and box a fabbed pcb of my own design. And scary to hit the stomp for the first Power up.
It is still the same Circuit as linked to above^^, but redesigned as a twosided pcb. The only main difference is the addition of a CLR and LED pad. The goal was to use boardmounted pots, make it fit in a BB enclosure, and i wanted to keep the "six pots gives a triangle"-design.
In short: This is a dual band highgain overdrive. It splits the signal in two fully phase-compensated frequency bands after the input buffer. Those two signals are then separately distorted/overdriven in two dirt Circuits based around a 4049UBE, before they are mixed together and run through a tunable two-pole LP filter for additional soundshaping. Finally a master volume.
It has been some interest around here to buy these fabbed PCB-s. I will come back regarding that subject, i want to try this very box a bit more before i start to spread them:)
Some pics:
the PCB
and the PCB with pots mounted:
Guts:
The Look:
again:
Look! I'm shrinking! Same same but different.
Cheeeeeerio folks!
muddyfox
very cool! what are the jumper wires? i cant really tell on my phone screen...
Sent from my iPhone using Tapatalk 2
wolfingsworth
Quote from: muddyfox on August 10, 2013, 11:16:12 PM
looks to me like ribbon cable connecting a dual gang pot. This is really cool! All those pots in a really nice layout. Good work Bengt!
Vallhagen
Thanx gentlemen!
And yes, it is ribbon wire connecting the dual gang pot to the pcb. I decided to go with a dual pot with solder lugs, not boardmounted.
hammerheadmusicman
Awesome work again! Now the board is verified, does that mean some are up for grabs? If so, put me down for one!!
George
Love it! Basically the same look as I was going for with my build.
kothoma
Vallhagen
Quote from: midwayfair on August 11, 2013, 04:22:43 AM
Excellent PCB layout, Bengt!
Thanx Jon!
Quote from: lincolnic on August 11, 2013, 04:31:58 AM
This looks great!
Thanx again!
Quote from: kothoma on August 11, 2013, 05:20:17 AM
Mønströüs, so to say.
Yep. a lil scaaary :o ... Hehe i dont have that "danish ö" on my kb ;D
Quote from: jkokura on August 11, 2013, 12:35:01 AM
Thanx Jacob! And thank you for teachin me/us so much about EAGLE. Without your videos i wouldnt have this design done!
Quote from: hammerheadmusicman on August 11, 2013, 12:13:30 AM
George
Thanx:)
Yes, some are up for grabs... verrrrry soon. I have one more thing to do, that is to take it down to my rehearsal room and do some fullvolume A/B testing, comparing this one to the earlier version. I want to verify that i haven't added anything strange ... as increased noise level or other artefacts. I think this can be done today.
I have re-read through the project thread, taking notes about earlier interest of the PCB. And i have one pcb put aside for each of you who has raised your hand in interest. So, i have one pcb for you George, as well as one for kothuma.
I'll be back:)
kothoma
Quote from: Vallhagen on August 11, 2013, 07:19:18 AM
Neither do I... (It's [Alt]+155 on Win and [Alt]+o on Mac.)
And i have one pcb put aside for each of you who has raised your hand in interest. So, i have one pcb for you George, as well as one for kothoma.
Thanks a lot! I'm really excited about it.
Vallhagen
ThePastRecedes
Hey there,
I'll take a PCB too if there are any left.
Thanks!
I build stuff for myself, sometimes I do 1 offs, I label them as HornBlende Audio.
Vallhagen
Thank you Pickdropper!
ThePastRecedes: Yes, i have one for you too:) ... But actually i think that was the last one.
Cheers!
