Zero Point SDX : Problem
Started by heavenwithin, August 11, 2013, 06:29:53 AM
heavenwithin
I built mine as per the build instructions. However on mode-1 there is random background noise , on mode 2 there is only 1 repeat when the path is switched on or off and on the other setting of path switch there is no repeat, mode 3 and mode 4 works perfectly. Every other knob/switch works perfectly. What could be causing this problem. Any ideas?
heavenwithin
I changed the Tl074 to a Tl084 and now everything is fine. The delays are sounding awesome. But will this fit in a 1590BB measuring 120mmx94mm? anybody tried it? Please suggest.
travorkates005
#3
Nice builds  :)
heavenwithin
Thanks for the threads' links kothoma... :D
kothoma
