Grid around the schematic?
Started by rullywowr, August 25, 2013, 12:18:28 AM
rullywowr
Just wondering how bean does the "map grid" around the schematic.  Its the border that has numbers 1,2,3 and letters: A,B,C and so forth.  Is this a feature in Eagle?
Haberdasher
i've never used one before but i think i know where they are.
in your menu bar, drop down library, use, and find frames.lbr.  i don't know which one madbean uses but there are a bunch in there to choose from iirc.
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
Stomptown
Iff you have the Madbean 2012 library the grids can be found in the "Frames" library.  Just add it like you would add any part to the .sch file when drawing the schematic in Eagle (i.e. just like adding resistor or capacitor).
Just use Draw-Frame from the menu bar and set it to the Info layer.  :)
rullywowr
Awesome!  I will give it a try. Thanks  :D
