1590a Jacks
Started by chromesphere, September 09, 2013, 11:29:48 PM
chromesphere
Hey guys,
Just wondering what sort of jacks you use when mounting a pcb ABOVE in/out jacks in a 1590a?  What am i talking about?  Probably easier if i just point to an example.  Jons a Bearhug of very little brain:
http://www.madbeanpedals.com/forum/index.php?topic=10851.msg97442#msg97442
Just wondering what type of jack you would need to to clear that board ontop? Will any switchcraft open style jack fit?
Cheers
Paul
Stomptown
Check out these: http://www.banzaimusic.com/Marshall-1-4-jack-PC-mount-mono.html
Most people use the stereo version found at small bear but they were out of stock last time I checked. There are other options but these are the most compact. If you look on the madbean project page Brian gas a 1590A baby board doc that has links to another option from snall bear, but like I said, these are better. Hope this helps!  :)
chromesphere
Cheers stomptown for the info.
hmmm. ok so it is a specific jack thats needed for this.  Those marshall 1/4 look really compact!  $7 each though is very pricey...I'll dig around some more, thanks again for the info.
Paul
haveyouseenhim
You can get 50 of them for $12 on ebay. They're from China, but the quality is really good. I've been using them with no issues.
I'm sorry sir, we only have the regular ohms
billstein
Quote from: haveyouseenhim on September 10, 2013, 12:20:00 AM
Would you have a link for that?
chromesphere
2nd that Billstein!  Would love a link Mike!
Cheers
Paul
chromesphere
Aha!  It seems the magic keyword search in ebay is "1/4 headphone pcb".  Thanks for the other links guys, but alas, im geographically handicapped and can not order from mouser, small bear, or most other international retailers.  It blows...
Paul
chromesphere
Im going with these ones.  Hopefully their not total !@#$.  Look the same as mikes and he reckons their good.  I would threaten you Mike with something like "so they better be go or else!" but I've seen how you repair guitars :D
Paul
http://www.ebay.com/itm/50pcs-1-4-6-35mm-Mono-PCB-PANEL-MOUNT-HEADPHONE-JACK-PLUG-2128-/400564170873?pt=US_Audio_Cables_Adapters&hash=item5d437c3079
croquet hoop
#10
Standard Switchcraft/Neutrik enclosed jacks still leave enough room for the PCB (unless there are huge components such as big 1 uF film caps); Juansolo and pickdropper have been using them in a number if 1590A builds. But yes, the smaller enclosed jacks are your best bet if you need to fit bigger components.
There is also the Neutrik NRJ6 series: http://fr.mouser.com/_/?Keyword=NRJ6&FS=True Only 12.7 mm high, 15.7 mm wide, fully threaded nose (not necessarily better, but I don't like jacks that protrude too much), and they're cheap.
haveyouseenhim
Quote from: billstein on September 10, 2013, 12:23:00 AM
I think the listing where I got em ended. I'll try to find the seller and search their store for another listing.
haveyouseenhim
Quote from: muddyfox on September 10, 2013, 01:46:30 AM
Quote from: chromesphere on September 10, 2013, 12:24:12 AM
I got me some here:
http://www.ebay.com/itm/120873501863?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
After looking at my purchase history this is the same seller. Just priced a few dollars more.
chromesphere
Those noses are a bit fuggly :-| Oh well, should be good enough for a few (25) builds.
micromegas
I think Pickdropper uses standard enclosed jacks for his 1590A builds...
Software Developer @ bela.io
