attenuator into my 50 watt tube amp
Started by garfo, September 14, 2013, 09:36:30 PM
garfo
So, I was checking this Dr Z attenuator, the Brake lite and it is a good idea for getting more out of the power tubes and still play the amp in a level that isn't killer in a rehearsal room or small venue.
My concerns are that this device is supposed to handle up to 45 watts, and my Bugera V55 combo is rated 50 watts.
I'm running it at 8 ohms and I'm not sure about this but aren't the tubes actually only working around 45 watts or so?
So, killer question is, is it safe to run this attenuator on my Bugera V55 combo???
Has anyone tried this specific combination, or something similar?
(By the way, my idea was not to run Master on 10, but around 8)
Short answer is, it wouldn't be recommended.  I'd go with one of the weber mass models rated for 100 watts.
Josh
Has anyone here made a attenuator? I just haven't seen to many DIY ones.. is there a reason for this?
garfo
#4
Quote from: selfdestroyer on September 15, 2013, 04:06:44 AM
Yeah, I was questioning this myself.I've seen some people who have buit, but I think you get stuck to just a limit in terms of power.If you want to get to 100 watts or more I don't think it is that easy or cheap to find the parts.
Found a project:
http://www.guitarplayer.com/article/power-attenuator-project/930
Thomas_H
Its not really a problem to DIY one.
You only need to do proper math regarding input and output impedance (resistance) when combining a few high power resistors.
Doing a good one always includes a coil to bring it closer to a real loudspeaker.
They have done a great job in offering a kit: https://www.tube-town.net/diy/tt-pos/tt-posx-en.html
DIY-PCBs and projects:
hammerheadmusicman
I have a dr z maz 18 amp, and I built a dr z air brake.
The break lite is up to 45 watts, and the air brake is the pricey one which does up to 100 watts.
I built an air brake and it sound killer.
I used this layout, complete with mouser numbers!
Be sure to buy the taps for the resistor, as they don't come with it.
http://www.andyharrison.net/files/AirbrakeLayout.jpg
Like I said, I use mine all the time, and it's not a tone destroyer like a lot of these kind of devices.
George
I play Guitar, and Build Stuff..
Twenty-nine page thread on the Airbrake at the Amp Garage. Pretty sure you need to register to see the pictures but can still read the posts.
http://ampgarage.com/forum/viewtopic.php?t=2402
Quote from: hammerheadmusicman on September 15, 2013, 04:28:37 PM
George
Thanks for all the info, Gives me something to read up on and see if its cost effective to build one or buy one. I did find a updated layout for the airbreak you posted and thought I would share it.
http://ampgarage.com/forum/files/attenuator_layout_final_195.pdf
hammerheadmusicman
As a guide, mine cost about £80 to build,
They are £200 to buy. In the  UK obviously.
garfo
#10
George
George, I was checking the parts on mouser(Portugal) and you can only order one of the coils(D100K25R) above 18 pieces.That's a bit pricey.They have orders that you can order only one, for example D100K25RE.Are they the same, do they both work equaly?
hammerheadmusicman
Really sorry dude, my grandad actually ordered the components for me as a birthday present!
So I have idea about the mouser ordering Etc..
Someone here will know though!
garfo
I checked with mouser.it's alright to get Only one.
By the way, is it necessary to cover the componentes with the special gel to dissipate heat?
hammerheadmusicman
We didn't, as long as its a big box with enough air in, it should be fine, my box has never felt 'hot to the touch', even after heavy gigs.
If it'd put your mind at rest, it wouldn't do any harm..
garfo
George, by the way, what impedances does this projecto work with?my amp is eorking on 8ohms at the mo.
