1590A Boneyard
Started by papasaurus84, September 24, 2013, 06:56:34 AM
RobA
Quote from: shawnee on September 28, 2013, 03:46:42 PM
Thank you Rob! On the LT1054, I am only putting 9v in but getting +/-18 volts out. I have done the same thing with a TC1044scpa with no problems.
You aren't doing the typical voltage doubler or negative voltage bit then. Are you doing something like Figure 24 from the LT1054 product sheet?
shawnee
Yep, that's the one. I don't understand it, but it works.   ;D
RobA
Cool, I'll have to try that one out. It looks like it would be good for getting +/- 15V for some of those synth circuits. Thanks!
shawnee
I found the layout on a Plexitone circuit that buck sears posted on the freestompboxes forum. It really is a great little circuit.
papasaurus84
guys,i found an 18v inverter to be added.so this babe's gonna run in 9v adaptor,but 18v inside.i promise i'll post it soon. :D
thousand dollars pedal and DIY is a GAS. the diffrence is the voltage: plus and minus. :D
papasaurus84
here's the schems for the voltage inverter...
RobA
That matches the Dual-Output voltage doubler circuit from the LT1054 spec sheet. The only difference I see is that the spec sheet version uses 1N4001 diodes. I've used 1N5817's with the LT1054 in their other example circuits and it has always been fine. It looks like a pretty slick circuit to use to me.
papasaurus84
Quote from: RobA on October 01, 2013, 04:09:34 AM
Yep. 4001 lower the output voltage much. but i still prefer this one because it's hard to find 5817 in my town. I've done layoutting in eagle but i'm not sure i'm doing right or not. here it is:
kothoma
If the bipolar version from the LT1054 spec sheet also works with the TC1044SCPA then it is reasonable to assume it will also work with an ICL7660SCPA?
papasaurus84
Quote from: kothoma on October 01, 2013, 07:42:45 AM
dunno for sure but i use 7660SCPA here... :)
papasaurus84
here updated layout,
i use a trimmer for volume and gain pots. i almost never adjust that knob so i decided to change that.
brejna
I have layout that is redrawn plexituna layout, I did check it 3-4 times..
here it is if you want it
Cheers
Brane
papasaurus84
whoa...thanks a lot brane. that's awesome. my latest post was 18volts 7660SCPA output so maybe lil bit diffrent there. it's not verified yet, but i'll try that soon...
brejna
You are welcome, I am pretty sure that layout is ok...
and whatever you do at the end give us results :D
Cheers
That's awesome! ...and I'm also slightly gutted as I yesterday populated a v1 boneyard to go into a a 1590B as a 3 knobber. That'd have been perfect for the job. Nev mind ;)
