Need help troubleshooting snarkdoodle(added ic voltages and pics)
Started by danwelsh, December 10, 2013, 05:23:10 PM
danwelsh
Hi guys.....having trouble with my snarkdoodle.....I have just a white noise for output. Volume pot works but gain has no effect....where do I even start? Thanks for any help
rullywowr
Start here...this will help you locate the information you need to obtain help from the many great members of the forum.  Without detailed information, it's near impossible to troubleshoot.  Welcome to the forum!   :)
http://www.madbeanpedals.com/forum/index.php?topic=902.0
danwelsh
What's the sound path for this circuit? I'm not good at schematics
kothoma
IN1, R2, C1, IC1A, (feedback loop: C2, R3, R4, GAIN), C3, IC1B, (feedback loop: C4, R5), C5, VOL, OUT1.
Essentially everything in the upper half of the schematic...
danwelsh
Quote from: kothoma on December 10, 2013, 11:10:32 PM
Thank you :)
danwelsh
Here's my voltage readings for the ic
Volts in-9.4
Pin 1-6.4
Pin2-6.4
Pin3-0
Pin4-2.38
Pin5-2.42
Pin6-6.4
Pin7-0
Pin8-0
Pin9-0
Pin10-6.4
Pin11-0
Pin12-6.4
Pin13-0
Pin14-0
Pin15-0
Pin16-0
All these zeros don't seem right to me.
Here's a few pics if someone could please help me with this.
I know I should have socketed but I didn't have one....I forgot when I made my parts order
kothoma
Pin 1 is very low. :( What did you use for R7? (All these 6.4V seem strange.)
Not sure what 2/3/4/5 are supposed to have. But let's look at the remaining pins.
Pin 15 should have the same voltage as 6/10/12. :(
Pins 7/8/9/11/14 having 0V is OK, they're grounded.
Pins 13/16 are irrelevant.
muddyfox
What's with all the black areas on your second picture? is it just some weird lighting on flux residue or are you actually burning the board? It really shouldn't look like that...  ???
Also, do you have an audioprobe?
kothoma
Yeah. How far did you get with your audio probe?
Also, that CD4049UBE is a CMOS device. You know these are sensitive to electrostatic discharge and have handled it with care?
danwelsh
Quote from: muddyfox on December 11, 2013, 09:43:30 AM
The black is just weird lighting....it rubs off. And yes I have an audio probe. I'll see how far I get with it after work today....got flustered last night and stopped
danwelsh
Quote from: kothoma on December 11, 2013, 09:31:32 AM
I quadruple checked all values....but I'll check again this evening.
danwelsh
Quote from: kothoma on December 11, 2013, 10:12:39 AM
Yes....I handle all ic's with care. I'll see how far I get with my probe after work.
